504 Farmall Gas
Booth2563
03-10-2008 14:48:08
Hello I have just found a 504 Farmall with a gas motor. I was told the motor was rebuilt about 3 years ago and not been run much since then. I looked it over real good and it is all there except mabe a metale shield on the side where it says 504 and the grill is missing and the tires are good and it has a wide front end on it never been broke or welded on. Oh yeaw he said it need a carbator. How much would this tractor be worth Let me know and I will let you all know what I can buy it for.
Thanks David
bc
03-10-2008 19:45:07
 Re: 504 Farmall Gas in reply to Booth2563, 03-10-2008 14:48:08
Leaving the grill off and needing a carb sounds like some imcomplete repairs and probably cause there are other more expensive problems.
Ask if he is selling it "as is, where is"? If so and you have a few hundred dollars to gamble with, then offer to buy it for a few hundred as is, where is. If you live nearby and he is willing to give a written money back guarantee that all the component parts are in good working order and in proper adjustment, then you could look at a higher offer. If he is wanting to sell it as is, then you can guess there are other problems.
TomH in PA
03-10-2008 18:42:10
Without it running you can't check the clutch, TA, PTO, power steering, or hydraulics, so I'd assume none of it works. Don't take his word that everything was fine last time he used it.
If it does run and everything else checks out mechanically it should be $2000-3000.
El Toro
03-10-2008 17:05:03
If I was buying it, I would want to hear it run.
That engine doesn't have sleeves and if it needs an overhaul the block would probably need to be rebored oversize. What is he asking? Hal
Booth2563
03-11-2008 08:52:10
 Re: 504 Farmall Gas in reply to El Toro, 03-10-2008 17:05:03
El Toro He is asking $750.00 for it
mkirsch
03-11-2008 10:14:01
 Re: 504 Farmall Gas in reply to Booth2563, 03-11-2008 08:52:10
If the engine is free, I would take a chance on it.
