How To Fix a Loose SC Front Rim Mounting Bracket
Larry in GA.
03-10-2008 17:25:49
I put one new tire on this afternoon and pulled the other one off , in doing so I noticed that one of the three rim mounting Tab is loose . What is the best way or is there one to fix this problem? Thanks Larry
gene bender
03-10-2008 17:30:10
 Re: How To Fix a Loose SC Front Rim Mounting Bracket in reply to Larry in GA., 03-10-2008 17:25:49
I dismount the tire and tube then bolt the rim back on the hub and weld the rivet fast again that way you dont spoil the exterior.
Janicholson
03-10-2008 17:37:31
 Re: How To Fix a Loose SC Front Rim Mounting Bracket in reply to gene bender, 03-10-2008 17:30:10
Good idea. When mounting it, make sure it is centered and has less than 1/16" runout, or it will always wobble. JimN
