Super M float stuck
Tractorfan1
03-12-2008 18:27:32
My '52 Super M hasn't been started in a few months. When I started it today, it ran fine for a few seconds, then started pouring black smoke. I think the float may be stuck. How do I go about freeing it up without taking the carb apart? Thanks.
Brett
CENTAUR
03-12-2008 19:32:44
 Re: Super M float stuck in reply to Tractorfan1, 03-12-2008 18:27:32
Shut off fuel supply by disconecting or shut-off valve.Then start up and run at fast idle till it runs out of fuel,then reconnect fuel and flush out any dirt that may be between the needle and seat. CENTAUR
Bob M
03-12-2008 19:02:52
Like Pete says a few raps on the float bowl with a wrench - or a block of wood - will usually free the float.
However if that doesn't do fix it you can drop the bowl to get at the float with the carb on the tractor. Simply remove the (4) cap screws that hold the bowl to the throttle body casting (7/16 wrench as I recall...). Then carefully lower the bowl.
Tractorfan1
03-12-2008 19:32:42
 Re: Super M float stuck in reply to Bob M, 03-12-2008 19:02:52
Bob M said: (quoted from post at 19:02:52 03/12/08) Like Pete says a few raps on the float bowl with a wrench - or a block of wood - will usually free the float.
Thanks to all for the help. I will try tapping the side of the bowl.
Don Cress
03-12-2008 19:00:36
Tap on the side of the carb. with a plastic hammer, that will un-stick it.....
sd pete
03-12-2008 18:42:04
Take a 15/16 wrench and rap the carb bowl.
