Farmall 404 wide front axle
Dave in Ms
03-17-2008 10:45:34
In an earlier post, ( http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=647068 ) I asked for help with identifying the front end that was used to convert our 404 from a tricycle set up. Here are some pics I took while repairing the broken pivot mount. If anyone recognizes this front axel assembly I would appreciate your sharing that info.
third party image
third party image
third party image
third party image
Allan In NE
03-17-2008 10:58:11
 Re: Farmall 404 wide front axle in reply to Dave in Ms, 03-17-2008 10:45:34
Sure looks like the correct IH front axle for that tractor.
Allan
Hugh MacKay
03-17-2008 16:09:38
 Re: Farmall 404 wide front axle in reply to Dave in Ms, 03-17-2008 11:14:36
Dave: Just in case you are a bit skeptical, Allan is right, after his tyrod correction.
Allan In NE
03-17-2008 11:35:32
That is a picture of an International (read: utility), which is completely different than the Farmalls.
They have a "swept back" style front end as opposed to your straight frontend with the axles out front.
Allan
Allan In NE
03-17-2008 11:37:40
 Re: Farmall 404 wide front axle in reply to Allan In NE, 03-17-2008 11:35:32
Duh!
Tie rods out front. :>)
Allan
Dave in Ms
03-18-2008 08:10:49
 Re: Farmall 404 wide front axle in reply to Allan In NE, 03-17-2008 11:37:40
I should have noticed the International name on the tractor in the picture. Especially since I must have been told a hundred times that the Farmall 404 and International 404 are different machines. Duh, duh, duh. Also I thought maybe it was just the angle of the shot that gave the swept back look to the axle. I said up front I wasn't a Farmall guy. Maybe a dunce tho? Ok, so with all that out of the way, are y'all telling me that my axle, with the tie rods out front, is correct for this tractor? If so, throw in a couple of duhs for Farmall.
