Farmall H rearend
Andrew Anderson
03-19-2008 16:56:08
Why does my farmall H have 2 gallons of water in the rearend? How did it get there? How do I Stop it?AHHHHH H Thanks alotin advance, andrew
neblinc
03-20-2008 08:47:18
 Re: Farmall H rearend in reply to Andrew Anderson, 03-19-2008 16:56:08
NBAllen said: (quoted from post at 11:31:31 03/20/08 Randy,
I meant to ask this earlier.
How did/do the o-rings hold up with the sharp edge of the lock washer?
How effective is the lock washer with the o-ring to bite into?
Nathaniel
I guess I should take one out and see if it was damaged or not. I tried to use a size that would fit tight in the hole, so hopefully the washer just pushed them in. Got the large assortment set at HF on sale.
Randy
neblinc
03-20-2008 06:36:03
GordoSD said: (quoted from post at 20:46:57 03/19/08 Neblinc. Post your photos of the oring washers here. Great tip for everyone.
Gordo
I did this on mine, not sure how much it will help, but better than nothing.
Randy
third party image
Don L C
03-20-2008 09:17:17
 Re: Farmall H rearend in reply to neblinc, 03-20-2008 06:36:03
Could you put a thin flat washer under the lock washer..... .....Tractor Supply should have them..... .Don
NBAllen
03-20-2008 08:31:31
Randy,
Nathaniel
Andy Motteberg
03-19-2008 20:32:54
That is common, especially if your tractor is left outside. Water can get in around the shifter or the bolts. Drain it and put in new 80-90 gear lube.
GordoSD
03-19-2008 17:46:57
Gordo
GordoSD
03-19-2008 17:46:04
Gordo
Scott Rukke
03-19-2008 17:44:59
Very common. Pulled nearly 4 gallons out of mine this summer. Tough to stop it. They're all right on how it gets there, condensation, through the shifter and through the bolt and filler hole threads. Good luck trying to stop it.
Yugrotcart
03-19-2008 17:06:56
Gets in through the bolt holes in the top of the transmission cover. Holes are recessed, traps the water. Remove each bolt and apply some sealer to the threads. Also condensation inside the tranny will contribute to the water.
Paul
wellsy
03-19-2008 17:04:22
we just drained about two gallons of water from my h i was told that it leaks in at the gear shifter i would just put some diesel or kerosene in it to clean out the rear end Colin
