farmall h engine rebuild
Bill Bowen
03-30-2008 07:42:49
I am rebuilding engine on my 47 h.Sent block and head and crankshaft to machine shop.Got my rebuild kit.Should be able to reassemble soon.I took pictures as I was taking it apart.The pictures did not come out.Is there a website that I could download diagrams for reassembly.Sure could use some help. Thank you in advance. Bill Bowen
neblinc
03-31-2008 08:11:54
 Re: farmall h engine rebuild in reply to Bill Bowen, 03-30-2008 07:42:49
I have a few pics on my WWW link below.
Randy
Wayne in MN
03-30-2008 14:56:39
Look at the lower right corner for parts search.
Try Super H when searching.
Janicholson
03-30-2008 08:23:40
IT manuals, Original Repair manuals, and the caseih.com parts diagrams are all very important for assembly and specifications. What one does not cover, the others will. I imagine several others will post images as well. Automotive books from the 1960s are also process oriented for use of torque wrenches etc. Clean and dust reduced conditions, Orderly assembly, and Use of assembly Lube (lubriplate) on bearings cam lobes, and journals (each and every with a thin film), pistons dipped in engine oil with rings on, Rings staggered 1/3 of the way around to avoid gap alignment, and clean (again) are critical. Keep us in the loop, JimN
