Hey You Smart Guys!
Allan In NE
04-05-2008 05:30:11
Before I go and put the duals on the wrong tractor, wanna ask.
How big of a tamdem IH disc with 20" blades will a 1066 handle? I mean, wheels up/no cheating, sucked in the ground width?
Will it pull a 20-22 footer okay in 4th?
Thanks,
Allan
casered
04-06-2008 21:01:11
 Re: Hey You Smart Guys! in reply to Allan In NE, 04-05-2008 05:30:11
I know this isnt a comparison for what you have, but its a good story. About three years ago we were running behind on some tillage work. Dad had the 7120 hooked into the big plows and was working it and we needed to get some ground disked as well so we could plant the next day, ( was suppose to rain alot after that and we wanted to turn and burn some ground before it hit). Anyway I hooked up the disk to our 766 to try and get enough done so he could start planting when he was done with the plowing.
The disk is a 16ft Krause cutting disk with 22" blades, and they were only on the disk about two years at the time so they weren't wore down hard. Now I could not come close to sinking it all the way in but it did handle the disk in lo 3rd with the torque ahead most of the time. There were some hills where it was a challenge but none the less that old girl did the job.
Needless to say I would not be inclined to ever do it again, and as soon as the Magnum was off the plows it was in the disk and the 23' Brillion packer was hooked on then as well and we were back in business as usual. As far as tires go the 766 did the work on 18.4-34's that are loaded and it has two sets of wheel weights, and the front bracket was empty. Our magnum even though its a little bigger than a 1066 pulls both the 16'disk and the 23'packer together on 18.4-42 duals with no additional rear ballast but it does have a fully loaded front weight rack. We have both heavy topsoil low ground and steep shaley knobs on our farm, so we cover the gammet as far as varying soil conditions. The magnum handles both with ease, before that we had a 1270 Case with 20.8-38 duals with cast hubs on both inner and outer wheels and it two handled both at the same time just as well. In fact there are times I think the old Case handled the two better than the newer tractor. There are times if were are just doing some touchup work that the duals are not on the tractor, but then usually we are not sinking the disk hard and the packer is not on either and it does fine. If that 1066 was on my farm I wouldn't be afraid for a minute to put a 20' disk behind it, but then again your soil might be heavier, but in our topsoil it would be NO problem.
Just my two cents on it.
Steven f/AZ
04-06-2008 15:44:47
Well, I've never heard of a hydraulic problem on a 66 series tractor as far as pressure goes. Yes, the capacity or GPM is a little low for some jobs, but a little extra time never hurt anyone.
Our 1086 basically has the same hydraulic system and the hydraulics haven't been touched since new and we are nearing 10,000 hours on it.
I'm with Hugh on the band type duals - I much prefer the hub mount duals - or even better, the heavy-duty cast iron hubs as on our JD 8630 and Case 2590:
third party image
Fancy Farm
04-06-2008 07:03:33
How fast you want to go you don't need to go faster than 5mph so load accordingly.
todd hamilton
04-06-2008 06:51:55
Well, if you can get the puny hydrolics on the 1066 to unfold the disc, and if you don't break the hub bolts on the axel after you dual it up it might pull that big ole thing on dry flat ground if you don't drop it in too deep. Seriously, we have a 1066 and a 1466 - it should pull it O.K. but that is about "maximum implement" for this tractor.
Hugh MacKay
04-06-2008 12:47:04
 Re: Hey You Smart Guys! in reply to todd hamilton, 04-06-2008 06:51:55
Todd: You must only use worn out 66 series tractors. I got a call one day, could I come and pull a Rockland Rotaveyor for a demonstration with my 1066 with 20.8x38 axle duals. They had been using a 185 HP Massey until the Rockland salesman got fed up with it's hydraulic performance. He wanted 200 hp, however there were none around, so the organizers called me.
A Rockland Rotaveyor puts hydraulic loads on a tractor that makes a folding wing disk look like a tinker toy. It's load on the 3 point hitch is in excess of 8,000#. We had to put 2,400 lbs. of front end weight on 1066. Even with that my operator had to be damn careful on turns, rough ground or hills. More than once that day I saw the front end 2-3 feet off the ground, even when you let the clutch out gently the front wheels lifted.
Well, the tractor came home from that, no broken axles, no busted hubs or wedge locks, no flat tires. I owned it for 16,000 hours, 9,000 of them after that day never replaced any of those things you mention. It did sell the salesman's machine for him, in fact at the end of the day he took my two operators out to dinner and also gave them a damn nice bonus.
Sure the 22' disk will be close to his limit, that is all the traction you can get out of 4-20.8x38 tires, don't matter how much weight you use. Weight only increases soil compaction. Been there and done that. May I also suggest if your breaking wedge lock wheels, you haven't read and followed the manual. If your not using axle duals on that much hp your a dummy.
todd hamilton
04-07-2008 03:39:07
 Re: Hey You Smart Guys! in reply to Hugh MacKay, 04-06-2008 12:47:04
Guys - my post was just some IH humor. Did not mean to upset anyone, sorry.
Hugh MacKay
04-07-2008 08:49:23
 Re: Hey You Smart Guys! in reply to todd hamilton, 04-07-2008 03:39:07
Todd: Didn't look like humor, may I suggest you not try and make a living as a commedian.
Ksfarmmer
04-05-2008 22:26:12
Pretty sure we pulled a 20 foot disk in NE KS with our 1066. May have even been 21 or 22.
Hugh MacKay
04-05-2008 20:38:52
Allan: I pulled, wheel up a Bush Hog with 88-20" blades on 20.8x38 duals with no chloride or wheel weights. I did use some front end weight. It hiked along in 4th, only ever needed to use TA for slow down. It was between 20' and 22'.
Not sure I agree with Gary's reasoning, now I realize you are talking 686, however my 656 never hit 2 IMP GPH on 44-20" blades. My 1066 did burn more than 6 IMP GPH on the 88 blade disk. Probably closer to 8 GPH
This is why I call large chassis 66 and 86 series two wheel drive tractors, YESTERDAY'S TRACTORS. They were not near as efficient as the tractors that preceeded them. If you folks are so all fired up about efficiency and getting good hourly pay for your time, split the tractor in the middle, put on 8-20.8x42 and install 350-400 hp engine. Then just buy up bigger chunks of Iowa and Nebraska.
Allan In NE
04-06-2008 02:43:23
 Re: Hey You Smart Guys! in reply to Hugh MacKay, 04-05-2008 20:38:52
Hugh,
Gary is talking in relative terms (country-speak) to make a point.
Dunno, he sure makes sense to me.
Allan
Hugh MacKay
04-06-2008 03:09:05
 Re: Hey You Smart Guys! in reply to Allan In NE, 04-06-2008 02:43:23
Allan: Of course he make sense, but I think the gap is wider than he suggested.
Jimmy King
04-05-2008 15:58:33
Allan, I have 16 ft Kewanee I pulled with my 756D. I know our soil is much different here than yours. In rocky areas it just rolls on top of the ground, but most fields have areas without any rocks and at 4 to 6 inches deep low 4 with no problem. I never did try it but I doubt I could have tied a drag behind it.
Steven f/AZ
04-05-2008 15:07:04
Well, if it makes you feel better, I've pulled a 14' Sunflower offset disc breaking sod with a 966 on 18.4x38 singles...
John A.
04-05-2008 13:56:55
Allan, In High Plains sand, either Blow-sand or good sandy loam I would stay just South of 20 ft. IMO we would pull an 18 ft offset with the JD 4630/4640, there were times they could give those tractors all they wanted, and sometimes is was like they were not even behind you. When you say 4th do you mean Lo-4th, TA not engaged? then,,,,IMO stay in the 18 to 20 range, keep your ground speed up and not lug the tractor back as much. Just my thoughts! Hope this helps.
Later,
John A.
Allan In NE
04-05-2008 14:52:37
 Re: Hey You Smart Guys! in reply to John A., 04-05-2008 13:56:55
Boy!
Hope I haven't stepped in a pile of hot and gooie here. Salesman was a bit skeptical. :>(
It's a done deal anywhoo.
Allan
Steven f/AZ
04-05-2008 08:42:41
Hey Allan, we have pulled a 28' John Deere 230 disc (deep cone blades) with our 1086 at about 140 horses. Worked the ground about 4 to 6 inches deep. It is one heck of a load, but will pull it. Also pulled a 22' field cultivator/chisel plow with 12" sweeps on it, along with a rod-weeder attachment, which definitaly pulls harder than a disc.
Short answer: Yep, you should handle 22 feet easily.
Harold H
04-05-2008 08:30:32
In our area, Mississippi Delta, a 21 foot IH 480 was always a good match for a 1066 or 1206 Farmall. With the heavier IH 500, 14 or 15 foot was a good match.
Harold H
jwal10
04-05-2008 08:00:01
Allan, I know you have cattle now and it takes more time away from your combine fun. But if it were me I would use the smaller tractor and have more fun time out there in the warm sun, enjoying the great outdoors. But thats just me :lol: :lol: :lol: :wink: :wink: . Oh but what a dilema to be in. :twisted: :twisted: :twisted: :wink: Just go have fun :) :) :) ....James
Allan In NE
04-05-2008 06:13:08
Thanks Fellas,
Thought I had this all figured out. Was gonna put the duals on the little 686 and use this 14' disc that I have. It pulls it just fine.
Then, I happen to spot the bigger disc. Just wondering if I ought to make that darned old 1066 earn it's keep around here.
Silly tractor has been rebuilt from stem to stern but just sits save for those years that I have to plow.
Don't like to have 'em "parked", as I don't think it does 'em a bit of good.
Allan
Lee in Iowa
04-05-2008 06:02:07
We pulled a 21 foot kewanee with a 1066 that was turned up a little bit. Ran it deep enough to wear off the bottom of the bearing flanges, had to cheat a little bit on the big hills. Lee
the tractor vet
04-05-2008 05:55:13
Well over here in the humps and bumps Our 1066 with 18.4 x 38's direct axle mounts We pull a 18 foot I H 470 and the tires are loaded on the mains i run 600 on the nose and on some of the hills that is more then enough not a power issue but traction . The way i have the pump set there is never a lack of power .
UncleBubbIH
04-05-2008 05:35:40
It should have no problem depending on how many ponies your running, we run a 20 footer with an 806 on 18.4 38's loaded. Its turned to about 130 HP, but that was 24 years ago, I think its lost a few. Depending on conditions we can run anywhere from 4th to 3rd. However she does pull kinda hard. Hope this helps a little.
Allan In NE
04-05-2008 05:57:33
 Re: Hey You Smart Guys! in reply to UncleBubbIH, 04-05-2008 05:35:40
That's kinda of what I was thinking. 22' would probably be the outside limit and it ought to fit nice on a 20'?
Thanks, I appreciate the help. Yeah, I turned it up to 145 hp.
Allan
UncleBubbIH
04-05-2008 06:12:53
 Re: Hey You Smart Guys! in reply to Allan In NE, 04-05-2008 05:57:33
Oh, well then, when the neighbors ask you to get the dirt out of their lawn, try not to smile. I have always wanted a 1066, our 966 just dont have the balls it needs, and I think its working for the oil companies, (DRINKS A LOT)
Allan In NE
04-05-2008 06:22:49
 Re: Hey You Smart Guys! in reply to UncleBubbIH, 04-05-2008 06:12:53
I hear ya there!
Last year I was working some ground with my 966 and the field cultivator.
Stopped right square in the middle of the field and turned that sow up to handle the "humps" a little better. Made a world of difference.
But yeah, both the 966 and 1066 will hog that fuel.
Kinda the reason I had planned on using the 686 for the heavy stuff this year. That darned thing will run all week on a tank of fuel. :>)
Allan
IaGary
04-05-2008 07:32:40
 Re: Hey You Smart Guys! in reply to Allan In NE, 04-05-2008 06:22:49
Ok Allan here is the deal.
If you run that 686 and it only burns 3 gal an hour on that disc, you will get about 3 acres disced on a gallon.
Now if you put a 20 footer behind the 1066 you will burn about 6 gallon an hour and get about 2.5 acres per gallon.
So 40 acres will take 13 gallons on the 686.
The 1066 will take 16 gallon to disc that forty acres
Your savings of about $14.
But you would spend 5 hours on the 686 and only 3 on the 1066.
Is your time worth more than $7.00 an hour as well as putting 5 hours of wear on the 686 and only 3 hours of wear on the 1066.
Your call.
Gary
