re setting Super C hydraulic stops
riverbend
04-06-2008 14:19:20
I have been picking away at the little details after getting the Super C running again. Checking for antifreeze in the oil - none, cleaning the points in the voltage regulator - charging now, retorqueing the head, checking the hydraulic oil, so far so good.
The hydraulic stops need to be reset. Reading the I&T manual, it sounds pretty straight forward except that the starter switch/battery cable is directly in line with and about 1" away from the front bolt on the left hand side. Even if I cut down an allen wrench, it will be very tight.
Is there a better way to do this ?
Greg
Janicholson
04-07-2008 14:28:38
 Re: re setting Super C hydraulic stops in reply to riverbend, 04-06-2008 14:19:20
Slip A small chunk of Vinyl hose on the Wrench!! JimN
Hugh MacKay
04-06-2008 16:10:23
Greg: Very likely you want the tractor running during this adjustment. Remove the starter, bolt the two wires together, put some electrical tape around them and crank start the tractor. Believe me a cut down allen wrench can get in contact with the starter terminals. Don't ask me how I know.
riverbend
04-06-2008 17:16:33
 Re: re setting Super C hydraulic stops in reply to Hugh MacKay, 04-06-2008 16:10:23
Hugh,
That's what I'm afraid of.
I suppose that I could weld up a crank...
Greg
