This is a new one on me
tn terry t
04-07-2008 19:02:37
just finished putting a alternator on my 230 i have the lite in line to excite the alternator to charge . problem is it wont excite through the lite. the lite is of the same type, mfg. same brand off the same shelf as the rest of my tractors[bought six at one time} now i can jump across the lite and the thing will start charging . BUT the second i remove the jumper it quits charging. All the rest of my tractors when you temporary excite the alternators they will continue charging untill you shut the tractor off. not this one . i've put on about twenty alternators on like this without any problems up untill now. could there be something wrong with the regulator in this chevy alternator?
tn terry t
04-08-2008 19:48:50
 Re: This is a new one on me in reply to ScottyHOMEy, 04-07-2008 19:02:37
oh yea its lighting up. i got it figured out now the reguator is bad when i put voltage to the number 2 post the alternator goes wide open and stays { as in pegs a 30 amp gauge} :shock:
Case Collector
04-08-2008 18:32:22
 Re: This is a new one on me in reply to tn terry t, 04-07-2008 19:02:37
Is the bulb a good bulb? It might be burned out.
Janicholson
04-08-2008 06:17:56
Checking the diode pack for abnormal operation is pretty straight from a delco repair manual. They can also be open causing issues with stability. The regulator sensing system might also be inoperative.
If full fielded, the output should be at the rating (usually stamped in the frame.
Getting it checked at the autostore is easiest. JimN
tn terry t
04-08-2008 04:17:42
 Re: This is a new one on me in reply to mulcher, 04-07-2008 19:02:37
Allan In NE said: (quoted from post at 06:09:23 04/08/08) Terry,
I think you have one leg fried in the alternator. Pull it apart; if one third of the stator is black, that stator is bad.
Allan
Thank you Allan that was what i was thinking
Allan In NE
04-08-2008 03:09:23
Terry,
Allan
tn terry t
04-07-2008 20:41:02
 Re: This is a new one on me in reply to Andy Motteberg, 04-07-2008 19:02:37
GA Dave said: (quoted from post at 22:18:34 04/07/08) Try a diode. David.
dunno i guess that diode would work but just dont think the alternator is zactly right i was just wondering if anyone else had seen this. normaly if you "flash" that #1 post the thing will charge untill ya shut it down this one aint
GA Dave
04-07-2008 19:18:34
Try a diode. David.
