H farmall brakes
Booth2563
04-10-2008 13:41:38
I need to know how thick are the pads on the brakes suppose to be? My right brake is adjusted all the way and it still wont stop the tractor.
Thanks David
Randy-IA
04-10-2008 14:45:05
 Re: H farmall brakes in reply to Booth2563, 04-10-2008 13:41:38
Hi , It could be oil soaked , it could be it's had so much grit and dirt in it over the years the brake drum is worn down to small , it could be the linkage is worn out inside . Have you taken it apart to look inside ? Are you talking about the pedal adjustment or the slack adjustment at the bottom of the cover ?...Randy
Bob Kerr
04-10-2008 18:52:38
 Re: H farmall brakes in reply to Randy-IA, 04-10-2008 14:45:05
Good point about the worn linkage inside Randy. My M had the band mounting pivot cracked at the pin weld and caused the brakes on that side to not work that good.
Matt from wi
04-10-2008 13:51:48
I just received a new set of brakes this afternoon for my h. I measured the brake pad not including the band and its 3/16 thick.
