Valve seals guide on a Super C
need a skidder
04-11-2008 16:34:25
I use my 52' Super C to drag logs. This year, it's smoking bad & oil is being blown out the exhaust. The tractor still runs excellent & I did a quick compression check & it's still good, very even. How big a job is it to install valve seals & guides? Can I do it in a morning? do i have to pull the head? Thanks
rd/oh
04-12-2008 17:30:30
 Re: Valve seals guide on a Super C in reply to need a skidder, 04-11-2008 16:34:25
When I had to replace seals or valve springs I had an adapter made to screw in the spark plug hole so I could hook an air hose to cylinder to hold the valves closed. I busted the center out of an old spark plug and welded a fitting onto it.good luck RD
Steven f/AZ
04-11-2008 17:09:22
Valve seals are a band-aid for worn valves and guides. None of our old Farmalls burn oil and none of them have valve seals.
Janicholson
04-11-2008 16:58:39
Pull the plugs, take off the valve operating mechanism. Rockers and Pushrods. Put a piece of cotton cloths line in the spark plug hole and turn the engine by hand till it is compressed against the valves. Use a spring compressor to remove the retainer and spring. Put on seals, and replace springs etc. Do all four, then reassemble the top end. JimN
ScottyHOMEy
04-11-2008 16:55:28
Guides will mean pulling the head.
Seals go under the spring so, unless somebody has a REALLY good reliable trick, you'll need to pull the head for them, too.
