Want to buy belly pump delete plugs
newhpuller
04-12-2008 05:13:06
Looking to buy (3) belly pump delete plugs.
For my 1944 H
danteiocona@comcast.net
sgt bull
04-12-2008 10:08:24
 Re: Want to buy belly pump delete plugs in reply to newhpuller, 04-12-2008 05:13:06
Go buy a couple of large corks. Drive 'em in, then take a safety razor and shear them off flush with the casting...
jal-SD
04-12-2008 07:23:25
The H we had that came from the factory without a belly pump had a big cast plate under the housing & the holes were plugged with corks. Wish I still had the plate. (My $0.02 worth. jal-SD)
tn terry t
04-12-2008 05:28:38
 Re: Want to buy belly pump delete plugs in reply to Andy Motteberg, 04-12-2008 05:13:06
go to your local auto parts store and get your self the proper sized freeze plug and drive in there or do like i did and just get those neopreene rubber freeze pluge and just tighten them up im thinking that a 1 3/8 is what i used but you better just measure across the holes your self
