Magneto and Cranking
Tims A
04-13-2008 14:18:53
I have had the oil pan and pump off my A. I rebuilt the pump and installed a new filter. When I get oil back in the pan,I would like to crank the engine over some prior to starting. If I do not have any plug wires on, will the magneto be damaged in any way by cranking? Or should it be grounded?
Thanks,
Tim
Janicholson
04-13-2008 14:45:31
 Re: Magneto and Cranking in reply to Tims A, 04-13-2008 14:18:53
If the magneto switch is in the off position, it is effectively shut off. No harm will come to it. The harm from disconnected plug wires is caused by the excess voltage taking any possible path to ground. This can begin the process of leaving carbon tracks, or short circuit paths for the High Voltage.
Just leave the switch in the stop position, and crank as needed. Do not crank more than 30 seconds at a time, then leave it cool for 2 minutes. Starter motors have a 20% duty cycle or so, and will overheat if run for long periods. JimN
Tims A
04-13-2008 15:58:49
 Re: Magneto and Cranking in reply to Janicholson, 04-13-2008 14:45:31
Thanks Jim,
Ground it out, and I'm good to go.
And I appreciate the concern for my cranking arm!
Tim
