IH 966 Clutch throw out bearing turns with clutch out
Jim Kreis
04-13-2008 18:54:51
put new clutch presure plate throw out bearing in and the throw out bearing turns when the clutch is released is this normal it has hdy asst the linkeage is off all the way it works fine other then bearing still turns wont that wear it out faster . the hdy asst is spring loaded so there is contant presure on the bearing
the tractor vet
04-13-2008 20:21:47
 Re: IH 966 Clutch throw out bearing turns with clutch out in reply to Jim Kreis, 04-13-2008 18:54:51
Your clutch adjustment is off . You must fallow the instructions for a hyd assit and like said below that it should be away from the clutch fingers .
Bill Lisbon
04-13-2008 19:26:41
The throw out bearing should not turn all the time . It should be away from the fingers at least 1/4 inch.
