Dual rear wheels installed on an HV Farmall
Jeff D Peterson
04-18-2008 21:51:59
I want to install dual rear wheels on an HV farmall. I assume that the only way to do it is to use rings and clamps. Does anyone have an advice for me on this matter? I am new this type of thing and dont know ehre to start. Thanks
Don L C
04-19-2008 08:54:01
 Re: Dual rear wheels installed on an HV Farmall in reply to Jeff D Peterson, 04-18-2008 21:51:59
Hi Jeff ---
I hope you are doing this for show.....The H is not strong enough for dualls..... .they would be sure to bust something in the drive line.....
Too put dualls on your H get another set of complete wheels and tites same size as yours....
Slide the first ones on with the wheels dished in..... .second set with wheels dished out..... .
Remember just drive it around.....do not put it in the field to work..... .
Zach Bouchard
04-19-2008 07:50:15
If your doing it for work purposes it isn"t useful. On an M you lose all of your power for turning the tires. HV final drive parts are not cheap, so I think about it first.
Harold H
04-19-2008 05:36:54
If I did I would install small tires. The high clear final drives are not designed for the extra stress of duals so tread lightly.
Harold H
