IHC 4568 V-8
:RIVIR
04-22-2008 19:47:07
had time too look at the V-800 engine that hasnt fired on the front two pistons, took the injecters out, started the tractor to see if the knock was still there, knock is reduced all right but crank case oil was coming out the injecter hole, 1 hole,where do you supposed the oil is coming from, i decided to fill the piston with diesel to see if piston was broken, but its holding full of diesel,any shots in the dark are welcome,at wits end, :~(
Edpap
04-22-2008 20:08:50
 Re: IHC 4568 V-8 in reply to :RIVIR, 04-22-2008 19:47:07
Hello,
I wish i had the engine in front of me, it would be lot simpler. but the first thing that I would check is the injector, have it pop tested I have in the past when I had no choice hook the injector to its line and run the tractor. most times you have to bend the injection line to do and that could be trouble. there isn't too many other things maybe the turbo or maybe oil is building up un the valve cover and running down the guides but is sounds like an injector. If it was just pouring fuel in the cyl it would mix with engine oil and carbon and look like oil.
I can get you injectors for $75 each.
Good Luck Ed
