Need Yer Brain
Allan In NE
04-26-2008 07:51:21
Okay,
Bought this tractor a couple of years ago and noticed that it had a master electrical switch mounted at the right sound insulator.
Didn't think a thing about it; ran it all that first year and it never gave me a lick of trouble.
As of late tho, if I don't throw that switch off when I shut the tractor down, it will run the batteries down over night. This must have been an old problem with the prior owner.
I'm thinkin' the only possible place it can be drainin' is either at the alternator or at that cab relay? Am I on the right track ya think?
Possible bleed across the ignition switch and feeding the relay?
Allan
third party image
GordoSD
04-26-2008 21:19:40
 Re: Need Yer Brain in reply to Allan In NE, 04-26-2008 07:51:21
Another question. It looks like you have the front gang at almost zero and the back at slot 4. Is that right? Is that how you pull that?
Gordo
GordoSD
04-26-2008 21:13:30
Allen, Is that an IH 16 SD rake in the background? VINTAGE raking!
Gordo
Scott Rukke
04-26-2008 20:26:27
You're welcome to use mine. In order to keep it in tip top shape I soak it in an alcohol solution. This seems to make it function a lot more efficiently. I have been told that this is due to survival of the fittest. The weaker and less fit brain cells are killed by the alcohol solution and only the fittest and smartest brain cells reproduce to make more smart and fit brain cells. So far it appears to be working. All I ask is that you keep it soaking while not is use.
GordoSD
04-26-2008 18:28:49
Allen, I know you like those catchy subject lines but it sure do get lost in the archives. Maybe try something a little more specific???
Gordo
the tractor vet
04-26-2008 17:00:23
You know how to go tracken down a short with a test lite i am sure and the wiring on them old hefers ain't rocket science . Plus who know what barnyard wiring has been done to it . Just got off the 1066 from cleaning barn today . Just about ready to put the plow to work but with that nice weather your sending this way I'll wait . May try and get the clutch done on the 806 and get to that center bearing on the clui monster that i have been putting off for four years . That job is a fingre pinchen ----- ---- nightmare.
TGIN
04-26-2008 15:10:37
Hey there Allan , Your more than welcom to use my brain but dont think it will help ya . It`s kinda dusty and aint been used in a while ! And it`s the type of brain that after scratchin it for a week it would tell me to put that master switch on there !!!
minnesota red
04-26-2008 10:21:21
the little solinoid(sp) for the cab is just,I would almost bet the farm on it.
JMS/.MN
04-26-2008 08:17:15
Brain is available- should be just like new, some say it"s never been used. I"ve heard of tracting leaks by using a low wattage bulb/socket, disconnect one wire at a time, short the pigtails to wire/terminal and ground. Glow should indicate the leaker, no glow, wire it back up. Only need one wire loose at a time.
Allan In NE
04-26-2008 08:37:36
 Re: Need Yer Brain in reply to JMS/.MN, 04-26-2008 08:17:15
Yes Sir, I'll use a test light.
The only two possible sources are that alternator battery lead and the relay trigger wire tho, don't ya think?
I "kinda" remember shutting it off two winters ago and the darned heater fan kept running; seems to me like I had to key the switch to kill it.
Makes me wonder about that ignition switch and if it is bleedin' across. Either that or the relay is hangin'?
I'll sure test it, but that alternator looks "relatively" new. :>(
Allan
