Snapping back H throttle
Mike CA
04-27-2008 08:23:17
While adjusting my H's carb I had to pull it into full throttle. It was difficult to pull it up there, and once there, it did not want to stay. The pull on the handle was so hard that the square teeth wouldn't hold the setting, and it would snap back to mid-throttle.
Is there a way to adjust the tension, or pull back, of the throttle lever? Or is it the govenor itself pulling back at it?
kaleb
04-27-2008 18:04:48
 Re: Snapping back H throttle in reply to Mike CA, 04-27-2008 08:23:17
hey ive got an old international harvester td6 bulldozer, and i cant get it to rev up... i have no clue where the throttle is, any ideas??
poorfarmall
04-29-2008 16:30:08
 Re: Snapping back H throttle in reply to kaleb, 04-27-2008 18:04:48
td6 throttle is one on top for dtesel gas part has no throttle
JT
04-27-2008 14:46:35
Make sure the teeth in your throttle are not worn out, also. mine was doing same thing, took off, refiled notches in dome, welded and filed the tooth on the handle, then did as Rusty Farmall suggested adjust fulcrum under hood about 2 turns, and no more problem.
Jim
Mike CA
04-27-2008 10:02:04
Yes, I know they work better, but I'm sticking to original.
Vito
04-27-2008 09:39:17
Mike,
Had the same problem.I changed to a M&W throttle lever adjusted the tension and it is working fine now.
Vito
SKK-Big Red Fan
04-27-2008 08:53:22
You do seem to have your share, don't ya Mikey! I just might have to fly out to Californy one of these days, to behold in person this process. I'm laughing with you, at you, at myself, and the world--but you do make me smile. Just keep on climbing that hill, you're a gettin there son, slow but sure. I'll try to email you latter when I get a little more time.
Mike CA
04-27-2008 08:39:25
Ok, so tinker about with that to find the right tension. I'll give that a go.
RustyFarmall
04-27-2008 08:44:54
 Re: Snapping back H throttle in reply to Mike CA, 04-27-2008 08:39:25
Yes, just tinker with it. I will also tell you that the procedure can be a bit frustrating, so be sure to wear your "patience" hat.
GordoSD
04-27-2008 15:27:24
 Re: Snapping back H throttle in reply to RustyFarmall, 04-27-2008 08:44:54
Rusty, That's funny. My Dad was always telling me NOT to "tinker" with things. His word for when I took things apart that were working just to see what made them tick.
Gordo
RustyFarmall
04-27-2008 08:38:01
The throttle should not be difficult to pull back, and it should stay where you put it unless those notches are worn out. Since you are having difficulty pulling it all the way back, I'm guessing that the linkage between the throttle lever and the fulcrum under the hood is mis-adjusted. I'm talking about that little gizmo that has a couple of springs and about three nuts on the threaded portion of the throttle rod. It's difficult to describe the exact procedure, but if you just dig into it, I think you will figure it out.
