Farmall 130 Rear Axle
Lewis Smith
04-28-2008 17:23:14
I thought I had a bad axle bearing on my Farmall 130, but somehow the axle is severely worn where the outer bearing is located. I have extra Super A final drives and axles taken from a parts tractor, but IH obviously made a change somewhere between the Super A and 130. I placed an ad in the classified for a 130, but to broaden the parts availability list, does anyone know if the 100 has the same axle as the 130 or the Super A?
Haas
04-29-2008 02:06:43
 Re: Farmall 130 Rear Axle in reply to Lewis Smith, 04-28-2008 17:23:14
According to my parts CD, the Super A and the 100-140 have different part numbers for the rear axles. Also, the LH and RH axles are different. For the !00-140, the LH axle is 362773 R1 and the RH is 362774 R1. Oddly, the high clear has the same axle for both sides, different than either of the regular ones, part number 362775 R1. The parts info for the Super A and A-1 tractors says the part numbers for the axles are: RH, 351823 R2 LH is 351824 R2. The RH one is noted to be for the Super A only, not the A-1. It does not say so, but I assume the A-1 RH axle would be the same as the 100-140. The axles for the Super AV also have different part numbers, but I suppose you don't need that info. For your purpose, it appears that the 100-140 axles would all be the same and you could broaden your ad to say 100-140, but you need to specify RH or LH whichever axle you need.
Hugh MacKay
04-28-2008 17:40:23
Lewis: Somewhere around Super A serial number 350000 an upgrade was made to final drives. I know the casting changed slightly, brakes changed. I've never checked the axle as my broken part was final drive casting. I suspect the axle change you are concerned about occured at the same time. I think you safe in assuming all 100, 130 and 140 axles are the same.
Go to CaseIH parts online, it may be discontinued hpwever it may still give you parts numbers for each tractor.
Lewis Smith
04-29-2008 07:21:10
 Re: Farmall 130 Rear Axle in reply to Hugh MacKay, 04-28-2008 17:40:23
Thanks guys,
I think the difference between the left and right is because of the planter drive being on the left axle. The left axle (sitting on the tractor) is the one I need, so if anyone has one for a 100-140 tractor, please let me know. So far, I haven't gotten any response from the ad I posted in the classified.
Thanks,
