Hyd oil in Distributor
RBTXS
05-02-2008 19:00:09
My SMTA live hydraulic pump is leaking fluid through the seal between the pump and the distributor. In the parts manual, there is a package #356 889 R91 which includes a gasket,rings, seal,washers,etc. Has anyone ever had this leak problem, and, if so, were you able to stop the leak by replacing this seal and seal ring? I don't want to replace the hydro pump. TOO much $$$$$$$$$$.
Janicholson
05-02-2008 19:45:14
 Re: Hyd oil in Distributor in reply to RBTXS, 05-02-2008 19:00:09
Go for it, they need clean, and there are issues with grooved shaft possible. Look to the search for box type in hydraulic pump seal, JimN
