Order Farmall Cub Parts Online
Cub Clutch disc
Curtis from Miz
05-04-2008 19:30:54
Can anyone tell me how to correctly install a new clutch disc. I can't tell the front from the back side of the disc. The only difference appears to be the housing that the splined shaft goes through, it is slightly longer on one side of the disc.
billde
05-04-2008 20:18:05
 Re: Cub Clutch disc in reply to Curtis from Mizzou, 05-04-2008 19:30:54
Don't forget to adjust those fingers.
old
05-04-2008 20:11:48
Longer side away from the flywheel. If you need more help and since you seem to be in Missouri send me and e-mail and I'd be happy to help if I can. Or check my web page for my phone number
ih560
05-04-2008 19:50:56
Curtis from Mizzou said: (quoted from post at 19:30:54 05/04/08) Can anyone tell me how to correctly install a new clutch disc. I can't tell the front from the back side of the disc. The only difference appears to be the housing that the splined shaft goes through, it is slightly longer on one side of the disc.
The longer end of the splined center will face towards the transmission and away from the flywheel.
Hope that helps.
Dustin Moran
Farm Parts And More
