A FARMALL STARTER
6GIBSON
05-07-2008 04:32:00
I REPLACED THE BRUSHES IN THE STARTER AND NOW WHEN YOU TRY TO START IT THE BENDIX WILL NOT ENGAGE. THE STARTER WAS TURNING SLOW SO HOOKED IT UP TO A CHARGER AND IT SPUN ALOT FASTER BUT STILL NOT ENGAGING. 12 VOLT SYSTEM
Bob M
05-07-2008 06:39:18
 Re: A FARMALL STARTER in reply to 6GIBSON, 05-07-2008 04:32:00
Sounds like either a weak battery or high resistance in a battery cable or the starter switch. (A healthy starter should literally slam the bendix out on 12 volts.)
Try feeding the starter directly with jumper cables from your car. You'll likely find it'll then crank just fine.
(Note: Your battery charger likely lacks output capacity (amps) to spin the starter up on 12 volts. So that test is pretty much meaningless.)
6GIBSON
05-07-2008 22:53:49
 Re: A FARMALL STARTER in reply to Bob M, 05-07-2008 06:39:18
I HAVE DONE ALL BUT THE JUMPER CABLES SO I WILL TRY THAT NEXT THANKS
Andrew Z
05-07-2008 05:15:56
Does the bendix move freely in and out? If not then Oil it up real good and see if it moves then, you may have some rust built up on there.
Andrew
6GIBSON
05-07-2008 22:52:22
 Re: A FARMALL STARTER in reply to Andrew Z, 05-07-2008 05:15:56
IT MOVES FREELY AND THERE IS NO RUST THANKS
