carburator kit for 2 cyl wisconsin on NH baler
VA Gasman
05-09-2008 07:49:18
I have an old New Holland baler that has a 2 cylinder Wisconsin engine on it. There is a ZENITH carburator on it that leaks out the bowl. I have did a google search for wisconsin parts and cannot find any info. Any one know where I can get the kit for this carburator?
I posted on this forum since a super H will pull it.
Thanks, Randy
JT
05-09-2008 19:20:25
 Re: carburator kit for 2 cyl wisconsin on NH baler in reply to VA Gasman, 05-09-2008 07:49:18
send me the model, I probably have one in stock
Jim
Vapet
05-09-2008 15:29:45
Thinking that I got my kit from NAPA, but I'm old and forgetful.
karl f
05-09-2008 11:07:52
get the carb number. Hygrade (standard motor products) makes basic kits for most models of zenith carbs. the float they do not. A good parts store that still uses books should be able to help.
otherwise, the company i work for has one store location in MN that is an authorized Wisconsin parts store. You will need engine model, serial, and spec/type number; and the carb number. 320-251-3221 ask for small engines except wednesdays and sundays, before 4pm central time. Only one guy handles that stuff. Gotta have all your info, as he's swamped and there are always variations.
online, i believe foley engines is also a vendor.
you may be able to deal with wisconsin directly as well, but i'm not sure.
karl f
