806 won't run
Daniel Chestnut
05-12-2008 19:04:19
I finally got done with getting my 806 ready to work this year. At lease I thought I was done. I used it one night last week to pull out our backhoe after getting it stuck. When I was bringing it back to the house it started to bog down and eventually died, but made it back to the shed. The following night I changed the fuel filters and made sure I had a good fuel flow to the pump, which I did. It ran good for a while so I shut it off and went to use it later. It just wanted to die. The t fitting ontop of the pump was leaking so I replaced it. After that it wouldn"t run at all. When I cracked a line at the injectors it didn"t seem like it was getting much fuel there, so I figure the pump must be bad. I had another pump that I took off a running engine acouple months ago, so I lined all the marks up like the Blue Ribbon Service manual said and installed it. Fired it up and it ran decent, but I believe it had air in the lines. After driving it around some it eventually died. It will start and run roughly five seconds. I blew air through the line from the primary filter to the fuel tank and the return line to the fuel tank. I know I blew the injector return line out and put part of it on new after I rebuilt the injectors. I"ve put on new hoses from the primary filter to the secondary filter. Plus the one from the secondary filter to the pump. When I got it it had set a few years without running much, so I drained all the fuel out and put new in. I"ve checked everything I can think of and I just don"t know what to do. I can"t imagine two pumps doing the same thing and being bad. Its just starting to get aggravating. Seems like all I get done to it is get one thing fixed and something else goes wrong with it. I"ve owned it a year now and I haven"t even been able to use it once. Anyways, any help is appreciated. Thanks in advance.
:RIVIR
05-13-2008 19:55:07
 Re: 806 won't run in reply to Daniel Chestnut, 05-12-2008 19:04:19
leave the fuel tank cap off while running in case you are creating a vaccume with a plug in fuel cap:~)
Daniel Chestnut
05-14-2008 09:33:58
 Re: 806 won't run in reply to :RIVIR, 05-13-2008 19:55:07
I tried that and it didn't make any difference.
dwag
05-13-2008 17:14:07
Sounds like fuel return line is plugged somewhere between pump and tank.
:RIVIR
05-13-2008 07:34:40
may someone changed something before you got the tractor, is it possible to post a picture of your tractor of the side where the fuel filters are :~)
davejoe
05-13-2008 04:21:06
The problem might be a restricted exhaust system, try removing the muffler and check it out, Dave
Daniel Chestnut
05-13-2008 09:47:49
 Re: 806 won't run in reply to davejoe, 05-13-2008 04:21:06
Its got a straight pipe on it. Maybe I can post a picture of the fuel filter side tonight.
:RIVIR
05-12-2008 19:33:30
How about air filter ?
Daniel Chestnut
05-13-2008 03:22:04
 Re: 806 won't run in reply to :RIVIR, 05-12-2008 19:33:30
I replaced the air filter also.
Daniel Chestnut
05-13-2008 18:31:35
 Re: 806 won't run in reply to Daniel Chestnut, 05-13-2008 03:22:04
Well, I did get it to run tonight. Someone told me to remove the ball thats in the fitting underneath the t fitting. So I removed the one in the old connector fitting and put it on. It started and ran for almost half an hour before I shut it off. At least I got it in the shed before another rain system comes in.
