international 1586
Chris28
05-14-2008 19:44:32
my 1586 will not start on its own, it needs a little shot of ether even after its been working, and even on warm days, if you turn it off, to restart it, you need either.....any suggestions? would sure appreciate any help...thanks
Steven f/AZ
05-15-2008 14:03:06
 Re: international 1586 in reply to Chris28, 05-14-2008 19:44:32
If you don't have a lot of blow-by or burning oil, I'd say it's time for a pump rebuild and/or injectors rebuilt.
Problem becomes instead of spraying a mist into the cylinder to be ignited, they "dribble" fuel in and it doesn't ignite well.
I'd have the injectors bench tested, followed by a compression test, and LASTLY go to a pump rebuild if the other two check out. I always start with the simplest/cheapest thing.
foothill
05-15-2008 11:48:52
our allis 7060 had the same problem, a new injection pump cured it. it had a Roosa Master on it.-ray
Allan In NE
05-15-2008 05:09:01
Chris,
Will it idle? If not, these guys are probably right and that pump needs attention.
However, and not to preach doom and gloom, but gotta tell ya, your symptom just screams low compression. Classic "I need an overhaul" trait. :>(
Allan
Chris28
05-15-2008 10:41:55
 Re: international 1586 in reply to Allan In NE, 05-15-2008 05:09:01
hello, yes the tractor idles fine, and runs great, it just wont start without ether, no matter if its been working for two hrs, and you turn it off, it wont start without ether.....
Allan In NE
05-15-2008 10:51:49
 Re: international 1586 in reply to Chris28, 05-15-2008 10:41:55
Good batteries/good starter? Spin plenty fast enough?
Dunno, but that's what diesels do.
When they get low on wind, they just don't wanna start. Then again, seem to run just fine once you can get the fire lit.
Good luck with 'er,
Allan
RR Mech
05-14-2008 20:30:09
You can almost bet if it wont start warmed up it needs a rebuilt injection pump.
mulcher
05-14-2008 20:06:56
Our 1586 had to have a new injector pump when it did what your talking about. It had about 7500 hours at the time.
Brian
