1006 TA - High Side Slip
Lance_MF_180
05-16-2008 07:44:01
Got a neighbor with a 1066 under heavy load will slip out of high range and into low range. Once load is reduced to slips back into high range. Low side Always pulls good. This is opposite as to what I have seen on my IH's. What the heck is going on?
Thanks
Kevin Meier
05-16-2008 15:23:13
 Re: 1006 TA - High Side Slip in reply to Lance_MF_180, 05-16-2008 07:44:01
Does it slip when the brakes are applied or steering is being used? You may have a bad pump, sump plug leaking, or plugged filter. You should make sure your adjustments are correct first and put a set of pressure gauges on to see if that is correct. When a t/a slips in direct drive it automatically is picked up by the sprag on the ta side and will cause more problems.
Janicholson
05-16-2008 09:49:19
Adjust it to spec. If it still slips, it needs a rebuild. JimN
Allan In NE
05-16-2008 08:30:06
I used to notice that when I drank a lot. :>)
Allan
