Axle mounts for Super C
Luke Miller
05-18-2008 08:08:47
Anyone have the axle mounts that attach a mounted plow and other attachments to the tractor. I have a mounted 2 bottom plow and want to attach it to our 51 Super C. Is there a rod that goes from the right side of the tractor down to the plow that lifts the front of the plow? I think that is all that is missing. I would like to find these items in central IL.
Randy in NE
05-19-2008 05:20:33
 Re: Axle mounts for Super C in reply to Luke Miller, 05-18-2008 08:08:47
The plow for the Super C has the lift rod on the right side. The C has the lift rod on the left and the depth adjustment on the right. The two plows are engineered totally different. I have never seen one mounted on a Super C but the C takes a rear rockshaft assembly that bolts to the rear axle. Drop me an email and I can send you some pictures of the plow on my C.
Luke Miller
05-18-2008 20:18:31
Thanks guys. Please email me some pictures so I know what I'm looking for. triplelpaints@yahoo.com
Brian Schmidt
05-18-2008 15:45:30
There is a rod on both sides. The one on the right lifts the front of the plow to control depth. The one on the left raises the plow out of the ground. I can find some pics if needed.
JimB2
05-18-2008 10:24:56
Hi Luke, the picture of C or SC that I have with plow attached shows the rod going from lift arm on left side of tractor. Can email you the picture. Just sent me an email at clarabrownlee@rogers.com and I will email you the picture I have.
Jimb
