Order Farmall Cub Parts Online
IH Cub tie road connector Shims
Gale Roberts
05-20-2008 12:54:10
Can anyone tell me the proper procedure for installing tie-rod connector shims and adjusting for proper clearances on my 1948 Cub tractor. I want to eliminate the excess movement up and down of the tie-rod ends at the steering arm. However I do not want to get it over tight at that point and cause binding and excessive wear. Thanks for any advice on this.....Gale
Roger46
05-20-2008 19:54:43
 Re: IH Cub tie road connector Shims in reply to Gale Roberts, 05-20-2008 12:54:10
Gale, I think when I did mine I bought several shim sizes and by trial and error added and took away shims. I took out shims until it wouldn't move and then added the thinnest shim for minimal clearance. One problem I have had with these is that the ball is not always round, so you need to check clearance with the tie rod at different angles. Roger
Gale Roberts
05-20-2008 20:41:24
 Re: IH Cub tie road connector Shims in reply to Roger46, 05-20-2008 19:54:43
Roger, Thanks for the advice. I appreciate it. Gale
