SH with mounted Kosch mower under the right side
VA Gasman
05-21-2008 17:55:12
Has anyone ever installed Kosch mower M19B a front mounted mower on a H , M or 300? I have it mounted but the manual talks about installing another spring and chain that will disengage tractors clutch and apply brake. I am unsure when this is to happen; maybe if the cutterbar hangs up when cutting.
No one around here has seen the Kosch brand before, it looks like a real good product.
Janicholson
05-21-2008 22:28:58
 Re: SH with mounted Kosch mower under the right side in reply to VA Gasman, 05-21-2008 17:55:12
If it has a breakaway release, the linkage would keep it from running over the unit with the rear tire. I can imagine a clutch link, but the brake system might be harder to arrange. If I had it I would attempt the clutch link, But probably not the brake component. Litigation society rules. Many manufacturers put safety information in sets of instructions to keep the law suits down. Good luck, e safe, and prudent. JimN
