656 hydraulic leak
Al
08-23-2000 18:22:21
I have a 656 with a hydraulic leak under the tractor. What are the possibilities that this is something simple? Thanks AL
kev
08-23-2000 21:12:25
 Re: 656 hydraulic leak in reply to Al, 08-23-2000 18:22:21
Hydroloc leaks are never easy, just a mess.
You need to clean up that area so that the leak can be pin pointed. Be carefull about over tightening connections, those fittings distort easy.
Eric
07-28-2003 21:39:13
 Re: Re: 656 hydraulic leak in reply to kev, 08-23-2000 21:12:25
I also have a leak on my 656. It is one of the hydraulic lines under the floor plate. Too much build-up of dirt, etc... has caused the lines to corrode and leak. I have to replace the lines because they are too far gone. Al is right. Clean the area real well where you think it may be coming from and look close as it starts to leak.
Ferrell
04-20-2004 11:59:21
 Re: Re: Re: 656 hydraulic leak in reply to Eric, 07-28-2003 21:39:13
Where is the leak towards the controls or by the pto handle. If it is by the controls there are two little O-rings that need to be replaced- it is a full day job but not to hard. If it is below the pto handle check the amount of hydraulic fluid you have there is an overflow there the same is on my 656 orchard model but it will stop once you drain out the excess or you can just leave it, it hurts nothing
