Fordson Super Major 3 point hitch problems
buckstrand
08-14-2007 09:18:57
First of all I would like to say this site is very informative and I really enjoy reading all thge previous post. I am a new member and just purchased my first tractor, a 1964 Fordson Super Major.
The three point hitch mechanism on it is not raising or lowering at all so I plan to lift the big cover (underneath the seat) to check everthing out. I would like have the necessary gasket, o-ring and anything else needed on hand once I do this. I see a hydraulic cover rep kit listed in the parts section but I was told it applies to 1965 and newer. btw, the oil in the diff seems a little milky.
Does anyone know what the kit part number I need is. Are there any other gasket/ o-ring or other kits I should also plan on having on hand once the project begins?
thank you for the help in advance
buckstrand
08-19-2007 20:17:59
 Re: Fordson Super Major 3 point hitch problems in reply to buckstrand, 08-14-2007 09:18:57
Well, I drained the oil and removed the filter cover today only to find the oil milky in color and the screen filter almost completely clogged. I plan on cleaning the screen and filling up with SAE 30 oil this week. given the 3 point has not been used in approx 20 years (according to the previous owner) should I still go ahead and lift the hydraulic cover?
Is there a way of checking to see if the unload valve is stuck without lifting the cover? if so how do I get to it?
sandy mac
08-20-2007 03:36:42
 Re: Fordson Super Major 3 point hitch problems in reply to buckstrand, 08-19-2007 20:17:59
You need to lift the top cover off. Its hard to describe how to take out the unload valve without pictures.....
sandy mac
08-19-2007 12:47:58
if the major has been unused for some time, its most likely the unload valve thats stuck.
buckstrand
08-15-2007 13:52:00
MJ, I did have the PTO engaged but still no reults consequently I am pulling the cover to see what I can find.
DAO, Would you happen to know who I can contact for the exact part numbers? I seem to be hitting a dead end...
thanks
DAO
08-16-2007 03:16:09
 Re: Fordson Super Major 3 point hitch problems in reply to buckstrand, 08-15-2007 13:52:00
I COULDNT TELL YOU THE EXACT PART #S FOR THAT. YOU CAN P/UP AN O RING KIT FOR ROUGHLY 20.ON CASE IH WEB SITE THEY LIST AS OBTAIN LOCALLY.JUST ABOUT ANY AUTO PARTS STORE CAN MATCH EM UP.YOU COULD ALSO GO TO WWW.CNH.COM UNDER FORD NEW HOLLAND THEY STILL LIST SOME PARTS FOR NEW FSM.I MIGHT HAVE MISSED SOMETHING ON THERE YOU MIGHT FIND.e-MAIL ME IF YOU NEED ANYTHING I MIGHT BE ABLE TO HELP YOU OUT.
dao
08-15-2007 12:17:16
other than your piston seal and cover gasket best i remember theres just standard o-rings that seal the piston to the cover and a seal for the supply tube.
MJ in the UK
08-14-2007 09:37:34
You do have to have the PTO running to drive the hyd pump on theise tractors. MJ
