Major Fuel System
GarryinNC
03-19-2008 17:47:51
It may be in the archives,but how does the injection pump and fuel control work on the Majors? The place where my dad worked had one when I was a kid and as I remember there was no direct linkage between the throttle and injection pump. I am thinking there was some kind of vacuum or air diaphram there.
It is still sitting there in the weeds somewhere so I am going to look at it first chance I get, it has a front end loader on it though so it may be hard to see in there.
I have been reading this site for years but this is my first post in the new format.
Thanks,Garry F.
Dandy Dave
03-25-2008 04:55:41
 Re: Major Fuel System in reply to GarryinNC, 03-19-2008 17:47:51
I recently purchased I&T manual FO-201. It has a lot of information about these pumps and govenors. A must if you own one of these tractors. Dave!
Bendee
03-24-2008 19:31:41
GET IT OUT OF THERE. yes, I am shouting.
lonzol
03-22-2008 18:27:16
where is the high idle setting at ?. my tractor runs way too fast and need calmed down,
tiresntracks
03-25-2008 22:05:36
 Re: Major Fuel System in reply to lonzol, 03-22-2008 18:27:16
There's a high-speed adjustment on the butterfly in the intake manifold, but I don't think that's your problem. You probably have a hole in the governor diaphram.
tiresntracks
03-19-2008 22:36:19
Hi Garry
You're right, there's no mechanical linkage, except on the Super Major with the Minimec injection pump. All the rest had a butterfly in the intake manifold that was controlled by the throttle lever, and two vacuum lines running from there to a diaphram on the injection pump. The diaphram is connected to the rack in the pump. When the butterfly is in the idle position, vacuum pulls the rack toward the no-fuel position. As the butterfly is opened, there is less vacuum and the rack is allowed to move toward the full-fuel position.
