1964 supermajor radiator
Jim K
12-13-2002 18:29:08
Any one know were to get new rads for supermajors mines rusted and busted tanks are busted up
Bill S.
12-14-2002 21:36:30
 Re: 1964 supermajor radiator in reply to Jim K, 12-13-2002 18:29:08
I don't have the answer you desire however I have had experience with a serious radiator failure on my 63 FSM. After a bit of measuring I decided I could bracket a 1978 (other years interchange) 6 cyl. Ford p/u radiator. It really was rather easy. If you need to get running this may be an interrim fix. You will have to leave the sheet metal off to access the cap. On the other hand a bit of solder work would give a rear facing fitting. I later secured a good used original radiator but have not fitted it as the p/u one is doing fine. Just extending the service life of the next (correct) one. Bill S. in Delaware, USA
P.S. There were no more where I got mine and since then they auctioned the salvage yard contents. What region of the world are you in?
