1963 2000 Dexta
Carl Bowers
11-17-1999 05:51:54
I have an english made 2000 dexta. Mine has a 4 cylinder Gas engine. All the literature that I can find only shows a 3 cylinder diesel. Was this tractor ever built with gasoline power?? or has it been modified.
I am also looking for any tips to alleviate an air lock in the cooling system. I replaced a temp guage and I now have an air lock after refilling. What is the easiest way to remedy this problem.
Kevin
11-17-1999 16:31:49
 Re: 1963 2000 Dexta in reply to Carl Bowers, 11-17-1999 05:51:54
I don't know if your tractor is a 2000 Dexta I think you have a Dexta. If I'm correct the 2000 Super Dexta didn't come out until 1964 or 65. I know Dexta's were available with a gas engine (I have 2 of them). The problem with the cooling system is the rad fill hose. When original the horizontal part of the hose was oval shaped, so it had a down hill slope to the rad but it hasn't been available for a whole bunch of years so you had to use the one for a diesel which is round because the rad was shorter. To fill the rad you have to slowly pour the antifreeze in and possibly undo the rad cap/fill mount tube (don't know exactly what to call it) and lift it up slightly.
Hope this helps
Kevin
