1959 Dexta Won't Idle
Jimba
04-12-2003 10:12:34
Hello, Just got this Dexta. Changed the filter, bled the system. Wouldn't start. I heated the intake with a torch. Still nothing. I gave it a tiny shot of starting fluid and to started right up. It runs a full speed. Is very slow to react to the throttle and won't Idle. Any Ideas? Thanks, Jim
jimba
04-21-2003 17:04:40
 Re: 1959 Dexta Won't Idle in reply to Jimba, 04-12-2003 10:12:34
Thanks for all of the help. I've started taking the tractor apart for a rebuild. I checked the vac tube and found a bad leak. The guv seems OK. I'll let you know what happens when I've got all the new parts and the injectors back. Thanks agian, Jim
ANTHONY TRAN
04-21-2003 10:55:55
Dear Sir/Madam:
We are a direct import/export company in Vietnam that specializes in selling used Japanese farm tractors. We export our tractors throughout the world. Our tractors are fully reconditioned and high quality tractors. We carry all kinds of tractors with brand names such as: Yanmar, Mitsubishi, Iseki, Kubota, Shibaura, Satoh, Hinomoto and many more… To satisfy our customers worldwide, we bought 4 giant warehouses on Highway 1 and Highway 20 in Vietnam to supply our customers with a large quantity of order. We also guarantee that our prices are competitive. We are seeking worldwide distributors for our tractors. Please let us know if you are interested to become our authorized distributor for our tractors. Please contact our representative office in California at 310-538-0724 or email: businesscenter@apcctran.com website: www.apcctran.com
Thank you for your time and we look forward to hear from you.
Sincerely,
Anthony Tran
President
Paul in Oz
04-12-2003 15:46:33
Have you tried giving the air filter a complete service? Also make sure the govenor vaccum line is air tight. Any leak will affect the idle i think. I'd give the starting fluid a miss if I were you. Its a really good way to extensively shorten the engine life. If the above dont make any difference, My next step would be injection pump timing. Then again it could be the govenor diaphram has a hole in it. Hmmm....lots of maybes. Someone with more experience may be of more help. Good luck
jimba
04-12-2003 19:51:26
 Re: Re: 1959 Dexta Won't Idle in reply to Paul in Oz, 04-12-2003 15:46:33
Thanks for the tips. I just noticed that the middle and the aft injector have fuel leaking from them. The aft one is bad. I'll check that tomarrow. Thanks, Jim
ray
04-12-2003 17:43:49
jimba,have you checked your lift pump at block.turn off fuel,take line off at lift pump.open your tap to ensure enough fuel is going to pump from tank, make sure there is enough flow from tank..then check to ensure lift pump is pushing enough fuel to filter,try that.sounds like not enough fuel to injector pump..or air lock at injector pump,crack a line on injector pump to ensure no air..my super major develops air locks all the time when i change filters...
WayneB
04-13-2003 18:28:15
 Re: Re: Re: 1959 Dexta Won't Idle in reply to ray, 04-12-2003 17:43:49
You said you heated the intake with a propane torch and gave it ether.
Is the glow plug still removed?
If it is, it will run a high idle until vacuum is restored.
Seal the vacuum, and then look at the inj pump diaphram.
Wayne
Rick
04-18-2003 20:43:40
 Re: Re: Re: Re: 1959 Dexta Won't Idle in reply to WayneB, 04-13-2003 18:28:15
My early dexta surges up and down at idle. The injector pump govenor was the problem.
ROY STOKES
04-20-2003 04:45:30
 Re: Re: Re: Re: Re: 1959 Dexta Won't Idle in reply to Rick, 04-18-2003 20:43:40
vacuum diaphram is almost certainly split,when ours went it run very fast at idle & around 8000 RPM with some throttle
