Big question I know, but....
grizz3000
10-14-2007 17:58:28
Okay, I want to get my land ready to graze cattle (two head) and two mini jersey cows. The land has shurgum on it for a few years, however nothing has been done to the land in two years.
Being new to all of this, where can I find some "how to" information on returning the field to grass land? I've tried my local extension office and they just say "plant some grass". Being an aerospace engineer, I want to think that the land needs to be 'worked' before I plant.
I have a 55 Ford 640 with a 3-point to do the work (slow maybe, but what's the rush?)
What is need is simple, plain talk, start-to-finish, on what I need to do.
I'd like to have half of the 40 acres grazing land, while the other possibly to grow some hay. Sickle mower? Harrough? Blades? Bailer? etc etc. Any recommended books? Videos?
Do I blade first? Harrow first? The questions go on and on and on.
Thanks in advance!
Eric
Clay in MI
10-15-2007 17:58:27
 Re: Big question I know, but.... in reply to grizz3000, 10-14-2007 17:58:28
You might find this book helpful.
Coloken
10-15-2007 06:35:30
Grizz, the best advice you can get is from some old boy who lives close and has farmed there for years. Provided he is not mad at you for buying the land out from under him. You will be suprised how frienly farmes get when you ask advice. Too late to work the ground now unless it is to drill seed into the "sorgum" . Brome grass and a mixture works OK there.
Allan In NE
10-15-2007 04:49:33
You gotta be careful out in that country/sand because the wind can come up and you'll end up with a 40 acre mini-dust-bowl. For darn sure, don't do anything with it now; too late in the season.
If it were mine, I'd wait until late April or May, disc it and drill it to Crested Wheat grass or a good pasture mix that fits your area.
Allan
grizz3000
10-14-2007 19:48:02
 Re: Big question I know, but.... in reply to CT8N, 10-14-2007 17:58:28
Actually, I did state I had 40 acres but granted I forgot a lot of other information too. Don't forget I'm new at this so I wasn't aware of the specific information that was needed. The soil is pretty sandy, and the area is on the plains East of Denver. They do a lot of 'dry farming' around here.
You used a lot of terms I'm not familiar with so I guess I better do some reading.
paul
10-16-2007 00:40:58
 Re: Big question I know, but.... in reply to grizz3000, 10-14-2007 19:48:02
Well dern, I missed the 40 acres. 20 of pasture. That site I mentioned also has a haying FAQ, probably even better at suggesting machinery to use for that.
You want to 'blade' the land, I'm not familiar with that term?
Here where it rains a lot & the soil is 120+ feet deep of mostly clay, I graze 20+ head on mostly 11 acres all summer, & get enough hay from some road ditches & field roads & 12 acres of alfalfa.
Don't know what to say about 20/20 acres of sandy ground in the west, way out of my element. :)
--->Paul
paul
10-14-2007 18:33:42
Read this:
Link
How many aces?
Your location, type of soil, & rainfall determines they types of forage to plant. You didn't supply any info.
Really, for 4 head of cattle anything will work, as suggested to you. :)
Soil test, add lime first if needed, then P&K, grasses will need constant N added; you can add a legume to the mix (alfalfa, clover) which will supply some N for you. Add P & K & lime every few years as needed.
If you can rotational graze (but probably need a bigger herd for that) your pastures will be much, much better. Critters tend to eat the tender stuff, & let the mature grasses or not so good stuff grow ripe. Over time this kills off the gooder grasses, & you end up with only the poorer stuff growing. Making 2-3 paddocks of your pasture & rotating every 30 days or so, would help. Takes a bit of planning to lay out the padocks to access water, shelter, from the different padocks.
Again, with 4 critters won't mean much, but if you plan to expand to 15 or more, plan ahead. :)
Ask more questions, read the supplied web link.
--->Paul
