Order Ford 8N Parts Online
'49 8N Ignition Problem
Ken T.
09-03-2000 14:06:24
About 3 weeks ago I was using the tractor and parked it. Didn't think I would would be using it again soon so I turned off the Gas an let it run till it stopped. Forgot to turn off the ignition, the next day decided I needed to us it and battery
was dead. Noticed that I had left the Ignition on, charged the battery over night, tried to start it again, wouldn't fire. Checked the front mounted distributer and found a buch of stuff had leaked out of the coil, looked like tar. Figured that I Had fried the coil. Ordered up a new 12 volt coil for it from Just-8n's. Also took the distributor off and took a look the points, thought they might be bad, looked good. Cleaned it up, as it has some of that tar looking stuff on it and checked to make sure that they operated
correctly with Ohm meter. Couple of days later the new coil arrived, put it on, tried to start it nothing. Well maybe the points and/or condenser were bad after all. Took it to the bench, I had a new set of Points, condeser and Spark plug wires that I was going to replace when I need to, but the old 8n was running so good I didn't want to mess with it. In any case when I went to remove the points I saw that the little copper strap that goes from the condenser mount to the points was just about broken thru, did a little sodder job on it. Checked with a ohm meter that I didn't short it to the baking plate and then went ahead and replaced the points, condenser, set the gap to .015 and set the timing by the book. Put it back on the tractor, with the
new 12v coil and sparkplug wires. Tried to start it, still would not start, checked and no spark at any plug wire. Check to make sure that I was still getting voltage at the coil. It was 6 volts, Said ah ah that is the problem, took the dropping resistor out of the circuit and now have
12 volts at coil. But still no spark. I did notice that the resistor was very warm (hot) when I went to remove it, sort of think that the coil is shorting out, but not sure how to check that in
line?
Any Ideas on what I can look at next? And what should be the voltage at the coil on a 12 volt system with a 12 volt coil?
Thanks
Ken
P.s. I have looked at the archives, but there were 1650 hits when I looked for "ingintion".
Don8NAZ
09-04-2000 09:26:47
 Re: '49 8N Ignition Problem in reply to Ken T., 09-03-2000 14:06:24
First things first. What kind of 12v coil do you have Internal or External Ballast (should be stamped right on the coil.
If it is an Internal Ballast coil, then you will/should have 12v at the BAT side of the coil directly from the keyswitch all the time the switch is on. The internal resistor inside the coil will automatically reduce the voltage to the coil windings sometime after you start your engine. (It's a thermal thing, you supply power, it heats up & changes resistance, hence current to the coil.)
If you have a coil marked External Ballast, you MUST have a ballast resistor wired in series from the keyswitch to the BAT connector on the coil. If you do not have the ballast resistor in series with the 12v from the keyswitch, you will fry the new coil in a matter of several minutes. Some have successfully used the resistor behind the tractor dash as a ballast resistor for coils marked External Ballast.
Be sure to check the wiring between the points and the distributor. Install the dist, and connect your voltmeter to the Points side of the coil. Rotate the dist by hand (or bump the starter) to get the points open. The voltage at the connector should be around 12v (6-12v is fine). Now rotate the dist so the points are closed. The same connector should read 0v. Anything else and the points or wiring are suspect.
By the way, grasp the dist shaft and try to rotate it. If it rotates freely, the distributor drive gear is broken. (But then you already checked for that, didn't you?)
When you are checking for spark, remove the spark cable from the central tower of the dist cap. Hold it with something insulated (plastic pliers, etc) and place the free end in close proximity of the engine block (1/8" or so). Keep it away from the fuel line. Crank the engine with the key on. A good spark verifies the coil. Reinstall the coil lead in the dist cap.
Now remove one of the spark plug wires from the dist cap. Insert a spring-clip lead in the hole in the cap, and holding the free end of the jumper with something insulated close to the engine block, crank the engine as before. A good spark here verifies the rotor.
Now hold the same lead close to the spark plug. No spark here means the plug is not firing. It may be gapped wrong, the spark may not be hot enough, who knows. Reinstall the plug wiring into the dist cap.
Remove the spark plug, reattach its wire from the cap. Rest the side of the plug against the engine (good ground) and crank the engine with the key on. This will test the plug.
Hope this helps. Let us know the results.
Don8NAZ
Ken T.
09-04-2000 19:16:38
 Re: Re: '49 8N Ignition Problem in reply to Don8NAZ, 09-04-2000 09:26:47
Thanks for the Advise Don,
Some of the information doesn't apply, as this
is a early 8n with the front mount distributor.
The coil is a 12 volt replacement for the 6 volt
coil that was on it. I had a dropping resistor in
line that I removed. After trying out the new coil
and getting no spark at all, (checking at a spark
plug wire) I took the "new Coil off" and found the
primary side spring terminal broken and shorting against the case. I will try to repair it using the terminal from the old coil and see what happens or I have to get another.
Thanks for the information.
Ken
Claus
09-03-2000 14:50:07
Did you turn the gas back on? I assume that by your point gap that you have a front mount distributor. Front mount 12 volt distributor, I calculate that you should have about 8 volts with the points closed and 12 volts with the points open. This voltage variation is very important since it would reveal if you had a short at the points and that the points are switching.
Happy Motoring
Claus
Ken T.
09-03-2000 15:05:53
 Re: Re: '49 8N Ignition Problem in reply to Claus, 09-03-2000 14:50:07
Claus,
And to answer your questions, yes it is a Front mount Distributor, and yes I had turned the gas
on. I checked the spark by takeing off the wires
and putting a screw driver in it and holding the shaft about a 1/16 of an inch from the top of the
sparkplug.
Thanks for the reply, When you said 8 volts with the points closed and 12 volts with them open, where should the voltage reading be taken?
The only voltage measurement I took was at the top
of the coil.
I am pretty sure they are opening and closing, at least they were on the bench.
Thanks,
Ken T.
Claus
09-03-2000 16:14:12
 Re: Re: Re: '49 8N Ignition Problem in reply to Ken T., 09-03-2000 15:05:53
At the coil....
Claus
