Tractor Talk Discussion Forum
14T Bailer
Gary Rowles
06-08-2007 11:03:22
Need help with my 14T as it wont make a tight bail no matter what i do. thanks in advance
David Snipes
06-08-2007 14:29:42
 Re: 14T Bailer in reply to Gary Rowles, 06-08-2007 11:03:22
The tension springs could be worn out.
mn.Chuck
06-08-2007 12:27:28
Gary, Most all square balers can have that trouble
if there are not enough chamber wedges in certain
conditions. Add some more-not important what brand
they are from. You need more resistance to the
alfalfa coming thru. Chuck
Walt Davies
06-08-2007 11:57:24
Adjust the feed forks to max and set tension on bales to near max then make sure that you have at least two rows from a 7 ft. mower feeding it at once. Or do as I did dump the thing on a neighbor and get a New Holland or case or even an IH.
Walt
