International TD24
Lloyd Ruhl
02-23-1999 07:00:34
I am in the process of negotiating a purchase of a TD 24. This crawler has been updated with a TD 25 motor(817 cubic inch, turbocharged). It has the planetary steering and 8 speed manual transmission. Does anyone have any experiance with a TD 24/25? What are the problem areas, if any? I await any input you may provide. What is a reasonable price for this crawler?
Rusty
04-17-2003 19:31:29
 Re: International TD24 in reply to Lloyd Ruhl, 02-23-1999 07:00:34
The steering can get buggy at times, but having worn several 24s and 25s out, if you keep the steering adjusted up, it's fairly trouble free and a blessing if you are doing sidehill work. Since you have the DT817 engine you're away from the heating problem that plagued the UD24 (1091) engines.
Rusty
Jyghgjhj
12-31-2004 16:59:20
 Re: Re: International TD24 in reply to Rusty, 04-17-2003 19:31:29
Hello rusty I two am about to buy a td24 and I would like to know how much it is worth.
Bud DeLong
02-24-1999 08:25:29
Had a T-9 T.D.18,and used to run a 1941 T -14 at
oldsmoble before i retired.All i know about the
24 is im told the 2speed steering gave trouble!! What does the iron look like?? a old tractor is
only as good as your iron because how much will
you spend on a 4,000-5,000 tractor?? Currently
i have a h.d.21 power shift chalmers thats been
souped-up with a 12v71 detroit.Bud DeLong.
