Moving a big rock
Stan
04-06-2002 06:03:38
Rock is about 2' X 2' and about 1' tall. What's the easiest way to move it ??
I'm thinking about rolling it on to a skid and pulling it. Any other thoughts would be apperciated. And, what to use for a skid ?
Charles Vesser
02-10-2006 20:43:29
 Re: Moving a big rock in reply to Stan, 04-06-2002 06:03:38
OK guys I'll admit I know nothing about moving a big rock. The first question I have is a 2'x2' rock that is 1' tall a big rock. Not really. I know that they are moved all the time. I don't think that rock would weight over 400 pounds if it was marble. Just call someone who sets tomestones they would know. I've seen many tombstones bigger than this!
Bart
04-07-2002 04:10:24
2'x2'x1' is not a big rock. The State of Vermont is a big rock. Good luck Stan.
john d - other options.....
04-06-2002 18:58:33
A 4' square piece of 3/4" plywood will do for a skid if you have nothing better. Depending on where the thing is, and how picky you are about where you put it, a stick of dynomite will move a rock that size several feet.....
Alberta Mike
04-06-2002 17:33:29
C'mon Stan, do what my old dad would've done ... get a big sledge and try to break it up in to pieces. Great for the bottom of the aquarium, plant pots, driveway, etc. Never mind that you might lose an eye, drive a wedge of rock into your forehead, or even get a hernia. That's what my dad would've done and I'm sure you're up to the task.
Jon D
04-06-2002 16:03:44
Push it with a loader...
BrettJ
04-06-2002 14:26:40
why not just leave it their
Ray
04-06-2002 13:45:06
Dig a big hole right beside it and roll it in.
No need to move it anywhere,it will be buried
for ever.
LarryG
04-08-2002 04:48:51
 Re: Re: Moving a big rock in reply to Ray, 04-06-2002 13:45:06
Just be careful doing that..... ..... .I buried a large rock that way only I dug underneath the rock too far and the gravel underneath gave way before I was ready. The short handled shovel saved my bacon as it got crushed by that rock because it gave me enough time to extract my leg out of the hole. I still have images of that shovel handle splintering - it could have been my bones. That shovel is still there.
Hal/WA
04-06-2002 12:27:52
I am assuming that the rock is already loose from the ground. If not, I use digging bars about 6 feet long to lever big rocks out of the soil, often using smaller rocks for a fulcrum. It is amazing how big a rock a person can move with a long enough lever. My tractor has a front loader that will lift pretty big rocks, but it is not always easy to get them into the bucket. I have levered the rocks into the bucket with the digging bars if I could not just roll them in. I also have just rolled very large rocks that the loader would not lift by putting the bucket a little off the ground and shoving with the tractor in first gear. I live on very rocky ground and pick rock all the time. I would not be without a loader--it is my most used implement by far.
When I was a kid, our old tractor did not have a loader. My Dad had what he called a stone boat that was made of the frame rails of some old car or truck cut off about 6 feet. It was turned over so the front curve of the rails was up, to give a sled runner effect. On top of the rails were 2" planks which made a solid, very low floor that we rolled or tossed the rocks on. We then dragged the stone boat to the rock piles with the tractor. Of course, the stone boat had to be unloaded by hand. It was a lot better than carrying each rock to the edge of the field, but still a lot of work. In my area there are huge piles of rocks that farmers have taken off the fields, probably mostly with stone boats.
I like the car hood idea--cheap and easy. Or ask a buddy to come over and show how strong his loader is! But if you have many rocks to move, I would consider getting a loader. Once you have one, you will wonder how you ever got along without one. I use mine for all sorts of things, not just moving rocks, dirt or manure.
rock puller
04-06-2002 11:49:49
simplist and cheapest thing i can think of is to take a chain and hook it around the rock and pull it away. Why waste time and money coming up with these cantraptions to slide it on to and them move iut with. Also who wants to try and roll or slide a rock that big onto something else so you can pull it away, it all sounds like a waste of time to me!
F14
04-06-2002 15:24:09
 Re: Re: Moving a big rock in reply to rock puller, 04-06-2002 11:49:49
You ever tried that? Like trying to keep a chain on a marble. Unless, of course, you're lucky enough to have a square rock...
Brian G. NY
04-06-2002 18:15:17
 Re: Re: Re: Moving a big rock in reply to F14, 04-06-2002 15:24:09
Most of the rocks in my part of NY are ragged enuf to pull with a chain that has a slip hook. We do occasionally get a round "hardhead" that you can't get a "bite" on. Them's the kind that rolls fairly readily.
Rock Puller
04-06-2002 21:25:19
 Re: Re: Re: Re: Moving a big rock in reply to Brian G. NY, 04-06-2002 18:15:17
never seen a square rock, but i have pulled a lot of rocks out of the ground and across my fileds this way
Ron
04-06-2002 10:27:11
If you can find one...I have and use our old "soil Surgeon".....it is great for working 1st- time over plowed ground, and it is solid- bottomed, so it is made to have rocks, or soil shoveled onto it for weight... If the knives are good, it does a job that can't be beat, working ground.... We kids rode on it, and rolled rocks and stones on it-- mile after mile...!!! You should be able to find one for "scrap price"....it is 4' square sections bolted side by side, to make it as wide as you like....
Sam at Classic Manor
04-06-2002 10:10:45
I've used the tire chains looped around the rock and attached to a tow chain to just drag it to where I want it. If you don't want to drag it, I guess you could use a boom pole to pick it up. My 2 cents. Thanks
Dave_Id
04-06-2002 08:12:13
Dig a hole along side of it, and push it in the hole and bury it.
RWK in WI
04-06-2002 06:32:48
I have posted this is the past so I appoligize if it is too familiar.
I have used a sheet of plywood 3/4" X 2X3' with a 2X6 bolted to one end with a chain fastened to the bottom of the 2X6 - roll or slide the rock on the plywood and when pulling on the chain the plywood bends enough to go over most bumps.
The other thing I have used is a chain basket.
Think of it this way. Take two light truck tire chains laid side by side with the distance between the two chains equal to the width of the cross chains. The existing cross links in each chain are attached to every fourth link on the side chains. Attach extra cross links to the second link between each cross chain connecting the two sets of chains. This gives you a chain net that can be draped around the rock and is more secure than trying to wrap a chain directly around the rock. By looping a tow chain through to corners of the net once it is around the rock you can close the basket and have an easy way to lift the rock.
Be careful, rocks are heavy.
Brian G. NY
04-06-2002 06:20:07
I'd just slide the bucket on my WD right under that stone and be off with it. Lacking that option, the next best thing would be to get your hands on an old fashioned "Stoneboat". At one time in this part of the country, every farmer had one, but I haven't seen one in 35 or 40 years. When I do find one, I'll fix it all up with some tough old elm planks and keep it around as a "conversation piece". By your description, you might be able to wrap a chain around it and just drag it. I've done that a few times when the stone was in a spot where I couldn't get right up to it with the bucket.
rhudson
04-06-2002 06:17:26
how about the hood of an old car?
F14
04-06-2002 07:40:14
 Re: Re: Moving a big rock in reply to rhudson, 04-06-2002 06:17:26
That's what I use. Put a couple of U-bolts through the front with BIG washers on the back to keep them from tearing out. Hook a chain in one U bolt, run it through a clevis on the drawbar of my tractor to the other Ubolt. Nice and low, easy to roll the rock onto, and slides across the grass without tearing the sod up.
It ain't purdy, but it works...
Roy
04-06-2002 09:31:51
 Re: Re: Re: Moving a big rock in reply to F14, 04-06-2002 07:40:14
You could always get a big hammer, then break it up into little rocks and throw them into a trailer.....now there's a thought....
Brian G. NY
04-06-2002 18:23:56
 Re: Re: Re: Re: Moving a big rock in reply to Roy, 04-06-2002 09:31:51
Come on over to my place; I've got a "hardhead" that appears to be about 3-1/2' in diam. that is burried in hardpan except for the top 10". All I want to do is knock off that top 10" or so! I was able to knock the top off of a limestone rock that lies only 15' away from this one.
Roy mi
04-06-2002 17:10:57
Sell it and the byer will move it. now thats a good thought.
Stan
04-06-2002 19:16:08
 Re: Re: Re: Re: Re: Moving a big rock in reply to Roy mi, 04-06-2002 17:10:57
Stoneboat, Plywood, Car Hood. Sell it to a neighbor. All good ideas. I'm going to try Stoneboat. I'll let you know how it goes. Thanks for the help.
