Voltage regulator hookup
David B
06-17-2003 20:20:57
Putting my M-H tractor back together, I have a Delco Remy 12 volt generator that was used before and have a new voltage regulator, regulator has three terminals marke Fld - Bat - and L. The only possible hook up leaves the L terminal to be wired to Arm terminal on gen. Is this going to work or will I ruin the regulator. David B
Big Dean
06-17-2003 22:43:12
 Re: Voltage regulator hookup in reply to David B, 06-17-2003 20:20:57
Check on the back of the regulator for a fourth terminal the Massey Ferguson that is where the GEN or ARM terminal is located
David B
06-18-2003 03:01:44
 Re: Re: Voltage regulator hookup in reply to Big Dean, 06-17-2003 22:43:12
There is no fourth terminal on this regulator
David B
06-18-2003 04:25:49
 Re: Re: Re: Voltage regulator hookup in reply to David B, 06-18-2003 03:01:44
Thanks Big Dean. This regulator sets on the generator and I removed it and found a fourth terminal underneath. Thanks, That is going to make the difference if my system works or not.
