Tractor Talk Discussion Forum
convert 12v Positive GND to 12V NEG GND how to
Don
07-25-2003 14:18:52
Hello a friend of mine has a 69 D15 i think its a a 69, maybe 66.... anyway it has a bad generator, 230 bucks for a rebuilt one..... .
and its a positive GND, can I change this to a Neg GND system, so i can use a GM Alternator, if so HOW do i do it, what do i need to do to change it over????? ?//// please send me the info.... thanks
My email----- -- > DLank68@aol.com
K-Mo
07-27-2003 08:10:56
 Re: convert 12v Positive GND to 12V NEG GND ho in reply to Don, 07-25-2003 14:18:52
An expert may be able give a definitive answer, but I think it may be a good idea to find a replacement condensor to match the switch from positive to negative ground. The condensor is an electrolytic capacitor which would make it polarity specific. On my Case 630 (Pos Gnd), the condensor has a red lead. On my other tractors (Neg Gnd), it's black. Same manufacture.
K-M0
Gene Davis(GA)
07-25-2003 19:27:44
and the amp meter also will have to be switched.
here, try this
07-25-2003 18:38:46
just switch the wires on the coil, and the battery of course.
Don
07-25-2003 19:32:07
 Re: Re: convert 12v Positive GND to 12V NEG GND in reply to here, try this, 07-25-2003 18:38:46
I do know just switing the coil leads will not work.... i will more then likely use a Chrysler coil and ballast resistor.... and as someone else stated switch the amp meter leads.....
thanks Guys
great advice and help
Bob
07-25-2003 20:31:07
 Re: Re: Re: convert 12v Positive GND to 12V NEG in reply to Don, 07-25-2003 19:32:07
If the system is already 12V, and the coil is in good working order, there is NO NEED to change it. Just reverse the wires. If it labeled (+) and (-), the (+) will go to the ignition switch, and the (-) will go to the distributor.
If the system is 6 volt, that would be another matter.
havvey
07-26-2003 06:08:44
 Re: Re: Re: Re: convert 12v Positive GND to 12V in reply to Bob, 07-25-2003 20:31:07
short version of long subject: you can put a delco alternator on it and change it to neg ground as the other posts stated with no problem you will have to change some wires and it will be cheap and generlly more effective i have done this many times
