Tractor Talk Discussion Forum
Ford 2000
new to tractor
07-27-2003 13:20:03
The pins sticking out of the sides of my differential that conect to the lower lift arms are loose and leak alot of oil. To tighten them I will have to pull the axle and axle tube on at least one side. My question is, when I pull the axle, will all the gears and stuff fall off into the bottom of the differential or is it somewhat like a floating axle? How hard a job is this?
thanks for the help(not).
08-02-2003 04:43:17
 Re: Ford 2000 in reply to new to tractor, 07-27-2003 13:20:03
thanks for all the reponses. Great tractor board. You will respond a thousand times to a scam posting but not once to a trator issue.
