Tractor Talk Discussion Forum
Tire Pressure?
COLBY TX
08-22-2003 11:29:25
I have a Ford 2000 diesel and it has 7.50-16 in the front. I just had new rubber put on and brought them home & bolted them up. I checked the psi and it was at 40psi. Isn't this super high? I do not have a loader, I just use it for bush hoggin and pulling disc. Shouldn't it be somewhere around 15-18psi? Also it has 12.4-32's in the rear, what about should I run in them?
Thanks
buickanddeere
08-24-2003 16:09:41
 Re: Tire Pressure? in reply to COLBY TX, 08-22-2003 11:29:25
Every body worries about soil compactions and install duals on the back. 12psi in the tire is 12psi plus a couple of psi in sidewall/tread stiffness. Yet they drive around rutting the soil with 40 psi in the front tires. The front just needs enough so they don't squat.15psi may well do.
DP
08-23-2003 05:29:40
The front tires should be in the 35 to 40 PSI range. As for the back ones, on a tractor that size, only guessing here, but thinking 10 to 12 PSI. A good way to tell is look at the tire where it meets with the ground and see that the full width of the tires are touching the ground.
Nebraska Cowman
08-22-2003 18:40:06
40 lbs does sound high for a smaller tractor. But those are bias ply tires the won't flex like the tires on your car. maybe 25 - 30 lbs. On the rear I cant tell you. somewhere around 15. I never use a gauge if they are fluid filled. It will ruin your gauge.
JMS/MN
08-23-2003 10:57:55
 Re: Re: Tire Pressure? in reply to Nebraska Cowman, 08-22-2003 18:40:06
Rotate the tire until the valve is at the top, above the fluid level. Will minimize damage to the gauge. Better to replace a gauge every couple of years than run the tires too low.
