Tractor Talk Discussion Forum
brush hog size
don
08-25-2003 08:43:03
i am contemplating the purchase of a ford 9N tractor- anyone tell me the recommended brush hog size for that??- also a good make?? thank you-Don
Steve (Magnolia, TX)
08-26-2003 07:03:54
 Re: brush hog size in reply to don, 08-25-2003 08:43:03
I use a 4' on my 8N. I'm confident that I could easily use a 5' in most stuff and even a 6' in light stuff... The 4' is easier to get into tight spots (between trees, etc... and I've got plenty of those), but the 5' will "cover your tracks" (standard 'N' width is ~5').
The horsepower differences between an 8N and a 9N are negligible...
DEFINETLY get the ORC... and limiter chains (or a 'Zane Thang') would be recommended, as the 9N does not have position control.
Steve
buck
08-25-2003 09:34:29
Assuming this tractor will be used mostly with the bushhog then consider another tractor but if you insist on the 9n then 5 ft. should be ok if the tractor is up to par on power.
Dog's Friend
08-25-2003 15:08:59
 Re: Re: brush hog size in reply to buck, 08-25-2003 09:34:29
As has been suggested here in the past, If you brush hog with a N series tractor, get an over running clutch (ORC). The N series does not have live PTO and the momentum of the mower will propel the tractor forward when you try to stop.
Tree Farmer
08-25-2003 19:31:56
 Re: Re: Re: brush hog size in reply to Dog's Friend, 08-25-2003 15:08:59
I have a Fergie TO-20 and opted for a 4 foot Bush Hog - Squealer Model. Well satisfied with it and still don't always make a full width cut if heavy going. Running over large clumps of Alder Brush, some up to 2" diam and Bush Hog chewed it up, but must have damaged my oil drain plug and/or seal - have a small repair to make. With the low HP tractors, I thought it would be better to go with a smaller width mower to insure adequate power. Have fun, but the overriding clutch is a must-have.
Ray,IN
08-25-2003 21:18:29
 Re: Re: Re: Re: brush hog size in reply to Tree Farmer, 08-25-2003 19:31:56
I also use a 4' cutter, a Woods M-4 to be specific. My T030 is occasionally taxed to its limits in hood high heavy grass and briars, forcing a downshift to 1st gear to keep from abusing it.If you only plan to mow pastures and easy stuff a 5' mower may be used. All farm impliments are HP rated to assist the customer choose the correct size for his tractor.
