Tractor Talk Discussion Forum
Wheel for a 3500 lb trailer axel
roadrunner
08-28-2003 23:21:40
I need a wheel or what people my age call a rim that will fir a 3500 lb trailer axel. Will a S10 or a Ford Ranger fit?
Thanks! roadrunner
Chances R
08-29-2003 06:12:21
 Re: Wheel for a 3500 lb trailer axel in reply to roadrunner, 08-28-2003 23:21:40
I belive you need to know how many lugs the wheel will need and the diameter of the whole spacing. If I was to bet I would say that you will have a 5 on 5, which if I remember right will be a chevy wheel.
roadrunner
08-29-2003 09:44:17
 Re: Re: Wheel for a 3500 lb trailer axel in reply to Chances R, 08-29-2003 06:12:21
Thanks for the information. The trailer has 14 inch tires and 5 lugs. As for the diameter of the hole spacing, I guess that all depends on what points you measure from.
Thanks, roadrunner
Chances R
08-29-2003 14:45:51
 Re: Re: Re: Wheel for a 3500 lb trailer axel in reply to roadrunner, 08-29-2003 09:44:17
It will probally work if you measure from the center of the axle to the center of the lug stud and multiply times 2.
roadrunner
08-29-2003 20:29:59
 Re: Re: Re: Re: Wheel for a 3500 lb trailer axel in reply to Chances R, 08-29-2003 14:45:51
You are right, it has a 5 inch hole diameter. I will check the Junkyard and find out what they have.
Thanks, roadrunner
T_Bone
08-29-2003 21:19:53
 Re: Re: Re: Re: Re: Wheel for a 3500 lb trailer a in reply to roadrunner, 08-29-2003 20:29:59
Hi Roadrunner,
Measure from the center of one blot hole to the far edge of a adjacent hole for a very close bolt center measurement.
T_Bone
