Tractor Talk Discussion Forum
Kubota 245 hydraulic problem
John
09-15-2003 15:49:17
Our Kubota L245DT has a problem, I first noticed the hydraulics were slow, especially when the bucket and the 3 point hitch were raised. I opened the centre compartment and the hyd fluid came bubbling out. The fluid is white and full of air even after running for only a couple of minutes. Any ideas what the problem could be? We can't see any leaks or anything obvious on the outside.
geok
09-15-2003 18:05:52
 Re: Kubota 245 hydraulic problem in reply to John, 09-15-2003 15:49:17
There should be a pick up screen located where your hydraulic intake line connects to the transmission housing. Remove and clean.
Gary-Miss
09-15-2003 19:58:37
 Re: Re: Kubota 245 hydraulic problem in reply to geok, 09-15-2003 18:05:52
My son's Kubota has the screen at the lower most point in the left side, held in with two small bolts. Most of them came out with transmission GREASE in the system, but, a change was sent out to switch to hydraulic fluid in the entire transmission , rear end and hydraulic system.
