Tractor Talk Discussion Forum
1964 2010 gas
scott
09-20-2003 20:48:33
I would like some help. My 2010 runs for about 20 min then starts choking, I have changed Spark plugs,condensor, coil, points, dist cap, wires.
Have also cleaned fuel filter, checked gas tank for crud ect. if i let it go to an idle it seems to clear up for about 2-5minutes. At wits end, could any one point me in the right direction. P.S. has good compression
LH
09-21-2003 08:55:50
 Re: 1964 2010 gas in reply to scott, 09-20-2003 20:48:33
Sounds like she is starvign for fuel, how about a new gas cap in case the vent is plugged and creating a vacuum in the tank
jls
09-21-2003 19:34:24
 Re: Re: 1964 2010 gas in reply to LH, 09-21-2003 08:55:50
had a Case doing the same thing, marvel carb had a drain on bottom of bowl that would work for a while, finally used POR gas tank sealer and fixed it.
