Tractor Talk Discussion Forum
restoring cub
craig
11-25-2003 18:00:29
does anyone know how to get the generator belt off? there seems to be a fixed nut inside a groove,and then a nut directly behind the generator pulley.
Bus Driver
11-26-2003 04:33:09
 Re: restoring cub in reply to craig, 11-25-2003 18:00:29
If memory serves correctly, the wrench to use is a 13/16" open end on the nut that is on the fan side of the vertical upright supports. The slots in the back will not permit the back nut to turn and any undue force may break the uprights. Some spray lube such as WD-40 on the back nut threads may help the process.
Ken
11-25-2003 19:08:43
The nut directly behind the pulley is the one to loosen. The second nut will be held in the groove. If the nuts haven't been loosened in awhile they may require a lot of force to loosen. Some PB Blaster will really help here.
craig
11-26-2003 17:27:47
 Re: Re: restoring cub in reply to Ken, 11-25-2003 19:08:43
thanks for your help..it worked.
