Tractor Talk Discussion Forum
body work vs. new sheet metal
drew
12-16-2003 16:21:58
I just got my first tractor, 1942 farmall A $ 100.00. It has been sitting 3 years but should be an easy fix. The body panels have some rot. Any opinions on body work vs. new panels. The hard part would be the grill, or $850.00 for new metal. I don't need an original type restoration but for it to be respectable, and just for work. It would probably be about an equal exchange my time or my money. Any thoughts?
Jonathan
12-16-2003 18:42:09
 Re: body work vs. new sheet metal in reply to drew, 12-16-2003 16:21:58
I'd buy a can of bondo and take my time doing a nice job sanding it smooth, you can make rust holes and dents disapear. good luck!
Ray
12-16-2003 18:18:00
You can buy a good old A for around $850 that
has good sheetmetal.
Nebraska Cowman
12-16-2003 18:09:42
or you could come out west and pick up some used tin reasonable. It don't rust here.
wdTom
12-16-2003 16:31:12
I see nothing wrong with welding in new metal to save old panels. Even if the weld is still somewhat visible. A grill is harder to fix if rusted, maybe a new, new used, or reproduction. Tractor sheet metal is often not made up of compound bends and is easier to repair with pieces you make and weld in.
